312mm brake upgrade
Just wondered if anyone knew if this kit will fit the vRS mk2 and if so will I need anything else or just what is supplied brembo
no the mk5 golf, mk2 octavia vRS, mk2 S3 chassis, brake kits will not fit the fabia.
However the kits from the Mk4 Golf, Mk1 Octavia vRS, mk 1 S3 will all fit the fabia. Im very tempted to fit the mk4 R32 Twin pot 323mm front brakes.
ie these or these R32 twinpots you would need to purchase the hoses, caliper carriers discs and pads though, but they are OEM standard so readily available
pop into the Mk1 Fabia section and check up all the 312mm threads there.
IIRC MK2 Vrs = same hubs as MK1
thanks guys :thumbup: I only asked as over on SCN people are looking to fit that kit to mk5 Ibiza cupras which I thought would be the same setup as mk2 vRS
Edited by adam1985
