Wheel spacers
Hi all, im getting really confused on the subject of wheel spacers so im after some advice
Hubcentric? Yes I have searched enough to understand why i need these.
BUT, do I use the longer bolts method or the spacer to hub, wheel to spacer method.
I need spacers to clear brembos, as there not fitted yet im not sure what size i need but i estimate atleast 15mm, 50% chance 20mm.
Soooo...
what type of wheels are they?
Can use either method but normally for under 20mm it's bolt through only.
17" pro race 1.2s
So if I used 20mm for ex, either method would be as safe as each other?
Safe maybe but depending on offset your going to be outside the arch.
its going to be a suck it and see im afraid... even with 20mm spacers could be close just depends on spoke's really...
