Climate Control Display Codes
Can anyone help identify a problem with the attached results from Climate Control Display in an '05 Octavia??
Symptoms are that I cannot get cold air at all but the climate dispay works as expected, so simply assumed a recharge of gas was needed to get cold air to the cabin. Got it leak checked and recharged but this was not required (as it was full already).
Thanks to this BRISKODA and have since been under the bonnet and found out the fans dont spin at all(but are free to do so) and the compressor wheel is turning on the belt(though I cant see if the centre nut-but CH19-4 implies it is at 1000rpm).
I cannot feel any temp change on the pipes going in or out the compressor after the engine is up to temperature (and with cabin settings on LO/Max fans).
Im have been reading about corroded wiring....should this be my next step or get it hooked up to VCDS?!?!
Not sure if this is your problem but was mine on my last car, the cabin filter was filthy and not part of main dealer servicing, changed it and air conditioning worked again. This was after having the air con re charged etc.
Good luck
Thanks for the idea-pollen filter changed and still no cold air!
