whirring noise
over the last few weeks a wearing (sp) noise can be heard quite loudly in the car.
It happens above 20mph. The noise does not increase with engine or road speed, its still there when I knock the car into neutral. Also when I put the car on full lock and pull away I can hear a scraping/rubbing noise I beleive. definitely not a CV joint noise
Its does sound a bit like a rotational noise but Im unsure due to it not increasing with road speed.
I did have cupra bushes put on the car 4+ weeks ago and temp steel wheels just before I noticed this noise.
Another thing to add my brakes are very low all round but are getting replaced soon.
Cheers for looking
Stephen
Edited by stevobeavo
If the pads are very low(through to metal backing plate), the run out on the disc could be creating the noise...
whirring noise ;)
Cheers Ad Lav
Well my pads only have 1-2mm on them. so im thinking mabye the backing plate is rubbing on the disc where the hub is?
Also found this :(
Dont thinks its this but looks like ill be re-packing it with grease as it coming out of the seal.
lovely,had the outer cv boot clip break on me,on the motorway talk about a mess grease everywhere :thumbdown:
