flexi pipe on cat
does anyone know the correct size for the flexi pipe on the standard cat for the vRS?
Need to know diameter and length.
Cheers!
100mm long, diameter.... i'd buy 54mm(ID)
Edited by tuplavee
thanks tuplavee! :)
Well i can be wrong! I have downpipe at work so can take measurements tomorrow if you want...
Or maybe someone has pipe nearer today?
At thinnest part i recall measuring 48mm, but it's larger where flex is...
If you could measure it than that would be great please.
Thank you!
Pics here: Downpipe Flex, measures
I'd go with 54mm, but it's your decision...
45mm at thinnest, near lambda... wow
thank you! :)
Great pictures there Tuplavee.
It's amazing how restrictive the standard downpipe is! My dad couldn't believe it when he saw mine the other day.
Are you replacing the whole pipe or just the flexi section?
Interesting to see the true measured output OD of the pipe for once (55.37mm / 2.18"). Did you measure the input OD of the cat-back system? I presume it will be the same diameter.
Nice waterproof vernier calipers by the way..... :thumbup:
just the flexi, though looking at it, the flexi on the pipe looks ok, just the weld that's gone.
