TPM Warning Light
I've a Yeti with no TPM option installed, however I've now got the TPM warning light coming on on my display. I've been in with the VCDS to change some functions, Seatbelt Warning sound, Cornering Fogs etc
Now my laptop has a very touch sensitive mouse pad and can sometimes pick up as a double click instead of a movement of the mouse. Think I must have somehow enabled the TPM system.
Been through all the menus but can find anything obvious.
Any ideas where to disable this function?
Found it, under 19 - Can Gateway, Installation List I had enabled the Tyre Pressure Monitor gateway coding option. Now removed and light is out :)
I've also disabled the double tab option on my laptop mousepad to prevent it thinking I'm selecting an option instead of moving the mouse.
