New Octavia - Trafficmaster
I have recently taken delivery of a new Octavia Elegance 2.0 TDI and am considering having Trafficmaster's Smartnav installed. However, I understand that the Octavia has a CANbus wiring system. Does anyone know if this is likely to pose a problem for the installation of Smartnav?
Hi Salmac,
No problem whatsoever - Smartnav requires perm +ve & -ve feed + I am sure a switched +ve, which if nowhere else could be derived from the back of the stereo and then a GSM and GPS antenna, both of which are supplied with the kit. I would recommend, if you can afford it, to get the touch screen as it does make it a much neater unit to use. Get it fitted professsionally, if you're not sure how to go about it!
Cheers,
John.
Many thanks for the reply, John. That's reassuring. If I do go ahead I'll get Trafficmaster to install. Will bear in mind what you say about the touchscreen. I had rather dismissed it because I can't see where it could conveniently be sited.
Colin
Hi Salmac' date='
Cheers,
John.[/quote']
One further question about Trafficmaster, John. How neat is the installation? Where do you have the speaker and button? Presumably it is necessary to cut a hole(s) in the dashboard to accommodate them.
Colin
