oil mixing with water/loss of water with no visable leak.
Oil cooler.
rotodiesel.
Edited by rotodiesel
Yes and make sure it's oil going into the water and not water into the oil or you will be needing a new engine pdq, best not to run it right now tbh.
Oil cooler.
rotodiesel.
its had a new oil cooler have you any other suggestions please.
it had a new oil cooler have you any other ideas please.
If the oil cooler has been replaced correctly and is not at fault then it could be the head gasket
Oil cooler sealing washer incorrectly seated.
rotodiesel.
rotodiesel.
if the washer is seated correctly,what could it be after that?
omg.. see a workshop :rofl:
