FMIC?
Has it been done? I have a hybrid turbo on mine and run a remap, and I'm thinking a bigger FMIC would be an idea as it'd look good too!
Has anyone done one on a Mk2?
they have a pretty good fmic as standard, dont know if the twintercooler forge do will fit the diesel?
As said, it's a pretty decent unit as standard.
I'd maybe looking at running some logs on VCDS first, if possible - to actually see if it's causing any heatsoak issues.
What sort of figures are you running with the setup as it is currently?
I wanted to fit the s3 one on my octy as I was changing the front end and heard that's the one to go for (might be diff on the diesel) but is a pricey boy even with a mate in Audi!!
The S3 IC isn't that expensive in the grand scheme of things. It is a very worthwhile upgrade.
I think on the diesel, the std injectors will run out of ideas quicker than the OEM IC. That's at circa 210bhp.
What power are you running at the moment Nick?
