what engine has it got..?
im trying to find out what engine etc my 1.9tdi has?
im looking at the service schedule manual and i cant make sense of it :no:
what would tell me which engine i have in my car? im wanting to know which bhp model it is.
does the following mean anything? - ac 96kw awx.
thanks
awx is the engine code 96kw is the power so convert kw into bhp your is the 130bhp varient
thanks for the quick reply mate :thumbup:
so i have the 130bhp model.! i wasnt expecting that.
what can i do to better the performance of this engine?
the only thing i have done is fitted a k&n replacement air filter.
also i "think" i may have a problem with the egr valve! that is if it is the egr valve?
does the egr valve sit to the right of the airbox? sort of above the turbocharger? if it is this then my egr valve is leaking oil.
should i replace or better still can the egr valve on this awx model be deleted without any error codes appearing?
Throw away the aftermarket air cleaner unless you want a contaminated MAF transducer, more noise and less efficient filtration. A new paper element from Mann & Hummel in a clean air box will give by far the best performance.
Check that the engine is not overfilled with oil and replace the EGR valve if it is leaking badly. Some oil leakage here is "almost" normal. Check that the crankcase breather pipe is unobstructed.
Don't fiddle with the AWX engine - it's easily the best engine ever fitted to the Mk 1 Superb. Look after it properly and don't bodge. If you do, it will bite you.
rotodiesel.
They do map quite well, Speak to Ben at shark performance im sure he could do you a nice map for better economy and better power without going silly,
As for panel filters not really much benefit unless your planning on keeping the car for ages then they can recoup there cost as they are washable, the k&Ns can cause problems with the mafs if over oiled, personally go for a standard filter and replace more often or find a non oiled one,
as said the egrs do leak oil depnding on how much to how bad it is, best thing to do would be take it off, clean it up(lots of guides on here) and refit, then keep an eye on it over the next few months,
One of the best mods is a catch can to stop the oil going into the system in the first place, again have a search lots of usefull threads even in the fabia section, similar principles just your engine is round the wrong way lol
as for egr deletes they prob do do them like in the fabia platform, ive got mine deleted and mapped out by Ben when i had it mapped so no cel light.
Hope this helps
rotodiesel.
awx is the best engine fitted to the mk1.! thats great.
i agree, im not really one for messing with something that is ok to start with :thumbup:
the only thing is that i am finding the car abit sluggish to drive, almost a lag type feeling.
i will see what i can do with the egr valve first :thumbup:
could someone possibly give me a link to where i can purchase a good quality egr valve but without the skoda/vw price tag
thanks.
get the car scanned it certainly shouldnt be sluggish, could be the maf playing up
getting the car scanned... is this a dealership only job or are there independant specialists out there?
sorry for my lack of knowledge but i am only used to old skool pushrod carbed engines.
are there any specialists in the derby or nottingham area that anyone is familiar with?
shark performance is in mansfield? they have the software to check for faults, unit 18 are milton keynes, check the site sponsers
DSB Autos in Bulwell have a good name - no first hand experience.
rotodiesel.
Easy way to tell engines is the TDi badge, totally silver is 105, red T is 115, red TD is 130, hth.
Plenty of badges on eBay - use engine code.
rotodiesel.
