Scan for a 2011 Superb Elegance
I have a 2011 superb and have switched off the DRL's and cannot see how I have done it. Can someone post a scan of module 09 for a superb to let me compare it to mine please.
Thanks in advance
Sinclair
Have you done it via VCDS or just in the MFD?
This is from my December 2010 (MY11) Elegance:
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 P HW: 1K0 937 087 P
Component: BCM PQ35 H+ 104 0615
Revision: 00104 AE
Coding: 40190AB8E87BF1C040080080110089E4427900AE736D87605C0140000040
Shop #: WSC 33361 790 00082
VCID: 3E788B0F10F1
Part No: 3T2 955 119 A
Component: Wischer 06101 26 0602
Coding: 00D7B7
Part No: 1K0 955 559 AH
Component: RLS 121010 05 54 0403
Coding: 072BED
Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
No fault code found.
I have also enabled byte 17, bit, 0 (which was 70 and is now 71) which is the adaptive/cornering light variant.
Revision: 00104 AE
VCID: 3E788B0F10F1
Coding: 00D7B7
Coding: 072BED
Thanks for that Gizmo. Just checked mine and apart from a difference in the tailgate lock all was the same, excluding byte 17, so there must be a fault elsewhere looks like a trip to the dealers since i haven't noticed them off since they coded the trailer socket
Sinclair
No problem,
My tailgate is electrically operated and I have disabled the 'beep' (when it opens).so that may the difference in coding there. :thumbup:
Did you ever sort this?
You may want to check out this thread where I did a similar thing, which I have since sorted :thumbup:
Yes I got it fixed,I took it back to the dealer, pleaded innocence and an hour later all fixed! My car had somehow lost the coding for the DRL's. I have read your other thread and will remember the coding for the lights in case I do something stupid again. Thanks for your intrest
Sinclair
...... I have read your other thread and will remember the coding for the lights in case I do something stupid again.
If you save an autoscan from the car, you will never have to worry about remembering the coding. It's all in the autoscan.
Unfortunately the Byte 18 code (31 in this case) is hidden behind a 'mask' of 00, so by using the autoscan coding will not help any to regain the OE coding as it was never visible.
Yes, I just learned this from Theresias - Sebastian.. He said these guys are making life more difficult and it is something I did not know about. So, my regrets... Usually, the Autoscan helps....
