how to make your skoda look like a audi in the pub
i was bored so i decided to take apart a old audi flip key, the blade can be removed by removing a small roll pin,
i then cut the blade from my key, ground the end down with a dremel and made it fit the flip key holder, you can remove the chip (carefully) & swop, (mine didnt need one)
you can use audi,vw, new skoda or a bently key,
i would only advise doing this if you have more than one key as you could easly damage the chip,
Whats the point? What is so special about Audi. All I see is cocks driving them
your rite about audi drivers, i was only saying how i used an old flip key, with out having to pay £30 for it
Lift up your bonnet and look closely at the individual parts and admire the VW and OOOO logos, from the MK2 Favorit (early 94) onwards.
Very true. Or the next time your in an Audi - check out how similar if not identical most of the interior is! Partically on Fabias / Octavias! The Felicia has many interior parts in line with a Mk3 Golf from memory, the steering wheel is the same!
