Felicia water leaking on clutch pedal
hi,
i have recently just bought another skoda felicia with a sunroof in and found out that its leaking. Does anyone know where i can get a replacement seal from in the midlands area or know of anyone on the net who does them. I have already tried jhm butt.
Try Jorily one of the site sponsers:
Skoda Parts - Jorily. The Skoda Parts Shop - Probably the UKs largest independent skoda parts supplier
If it isn't listed in the shop just give him a ring or email and he will probably add it for you to buy.
If he can't help you I don't know who can?!! :thumbup:
P.s. before you order a new one... have you tried cleaning the seal?
Maybe removed the sunroof glass and removed the seal and give it a good clean in soapy water. Did this with the door seals on the Pug 306 that were leaking and it stopped it full stop. I also sprayed a bit of WD40 on the edge of seal that makes contact with the body of the car.
Phil
Glass to frame seal -
  • 1 year later...
Solved my Felicia water leak by DGW's method, damn funnel thing was stuffed with mud, thanx a lot DGW!
  • 1 year later...
i have a 98,felicia with water leaking on to the pedals i have removed the heater box and checked the small rad inside. i also removed all the switches and dials from the dash what i can see is the sound proof mat is dry at the top where the clocks and dials sit but very wet at the bottom.i have checked the windscreen seal as well.is there any other places around the bulkhead that are prone to leaks if anybody knows please give me a rely.
  • 2 months later...
Ive also just cleared the mud from bottom of cooler system.Didnt seem much there,but didnt try and have a good look with the mirror.might take the whole cover off and clean out that way. will post again if both sides of the footwell foam drys out.sealed the windscreen with a thin bead of the clear sticks like **** so cant see it being the screen
