engine mgt and glow plug warning lights coming on
Not a good day.
Engine mgt and glow plug (I'm not sure that is the correct technical term but you know what I mean) warning lights have come on and car gone in to "get you home mode"emoticon-0120-doh.gif
Just covered 13k from new (Sept 2010) so not expecting this (although previous bad experience with an A4 Avant should have prepared me for VAG reliability issues!).
Is this a common problem? ANy ideas?
Looks like a date with the dealer is in order emoticon-0106-crying.gifemoticon-0106-crying.gifemoticon-0106-crying.gif
Not a good day.
Typically both your braking lights are burnt or you have a faulty brake pedal switch. Probadly the last ...
So .. check your braking lights ?
Took the car to the dealer - diagnosed as faulty EGR valve (at 13k - not impressed! - previous 2 CDTI Hondas required ZERO engine work in over 200k miles).
Even more bad news - part is out of stock at VAG and will not be available until the 20th June - dealer thinks there is a potential problem with EGRS.
Have a new Passat Estate as temp replacement - apart from having DSG not a patch on the Superb.
Ok, thats sad. Hope a new valve will sort it out for you.
