Dipping mirror on reverse?
Is the dipping passenger mirror on reverse only possible to code in pre-fl Mk2 Octavia with the electric seat? Or can it be done on any Mk2 Octavia?
Finding it very handy in the loan X1 after work car pranged, and may help stop SWMBO kerbing the alloys on our car. :yes:
Can't be done on my fl elegance, I've set it but it has no effect.
Bag goes that idea then. Thanks anyway Matt
Only possible if you have electric memory seats as it needs the memory function to know where to set the mirror position to each time.
Ian
Ian
You don't need memory seats
You do require a MAX version door controller which has memory function. And the motor in the mirror needs to be a memory version. Both can be retrofitted
Do you have an idea of price & part numbers needed?
options for memory window Door controller (also supports Electric folding, Auto Dimming) Price £220
1T0 959 702 N Z0Z
1T0 959 702 S Z0A
Mirror motor
3D0 959 578 C price £75
very expensive, best to look for them second hand. Will also require extra wires to be added as the current miror motor uses 3 wires and the memory version uses 7 wires
Thanks. Seems a bit expensive and agro to do.
Perhaps the Mk3 will have it as standard on some specs.
