aaaaaahhhh not again!
My running too lean engine management light is back on.... replaced the split Y piece crank case breather hose and also the split S pipe that connects to it, and yet its still coming up, the revs aren't as static anymore but the eml still appears...
Where do I look next...? ..my forge recirc r valve?? The adjustable one.
Could be another boost leak or maybe even a duff maf sensor.
Oh and if you have the standard dump valve try that.
The revs have been alot better so if it is still a boost leak, then im slowly but surely plugging the holes,
Oh and the EML reading is only saying ... 'System running too lean'. its not coming up with the 2 or 3 others like 'RPM higher than expected' and stuff.... just that first single code
Im gonna have to try standard DV i think,
But doesnt the same light as when you turn ASR off come up when your MAF is unplugged or not working?
Hmm. myt have to invest in a MAF and bite the bullet just for the chance
:( sad face!
Edited by Milkybadger
