AUQ inlet manifold occy VRS
I bought a polished AUQ inlet manifold off ebay but looking at mine it has 2 connections underneath whereas the one ive just bought only has one? :'( Is there any way this will fit my 03 occy VRS? Part number is 06A 133 223 CC. Thanks
One of mine is blocked off as my boost system has been modified. I'm sure you can make it work.
Could I remove the suction spray system? and use the manifold ok? What do I need to do this? Hoses etc
Both mine are blocked off (looped together), so you'll be able to make it work especially if you simplify your breather system/vac lines :thumbup:
Edited by sivrs
Or just get a Y splitter for the vac lines.
