Skoda electric windows
I recently purchased a Skoda Yeti Elegance and have previously used the 'holding' lock button which centralises all the windows closing together. Yesterday I discovered however my driver side window does not activate once this function is carried out. The other 3 close accordingly. All windows work perfectly well when individually operated. Is there something quirky that is stopping this function performing?
I previously noted the rear washer not working before discovering it was because the boot was not closed correctly. Is it something like this? I have checked my door was shut by the way.
Many thanks
Glen
Edited by GLEN5472
No the window will open or close even with the door wide open, I often use this facility.
Not sure why your drivers one doesn't move, could be one of the settings accessible through the maxidot under convenience?
Thanks, it was on all for window operation however I switched it to driver only then back to all and it seems to be working fine now! Thanks for your help, perhaps I should get my head in the manual a bit more!
