Coding for Cruise Control help please
Guys
I have purchased a VAGCOM kit from RossTech.
I am trying to install my CC - the stalk and everything is fitted.
I am trying to copy the coding from here which I presume is correct?
However, on the Engine bit I get to this and am now stuck:
Can anyone shed some light on where to go next? The Coding=11 box is greyed out.
I also wanted to turn on anti hijack, but cant see how to get to that option?
Thanks - got it working!
A couple of other bits - I have enabled the horn (siren) when locking with the fob, however there is no sound. Do I need to activate / turn the siren on or volume up somehow too?
Also is it possible to code the instruments / cluster lights to be on constantly when the ignition is on?
Start with posting an Auto-Scan please.
Wednesday,06,July,2011,14:08:09:00230
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
Mileage: 60560km/37630miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 A HW: 1Z0 907 115
Component: 2.0l R4/4V TFSI 0040
Revision: --H14--- Serial number: SKZ7Z0F3411022
Coding: 0203000318070060
Shop #: WSC 28069 576 88121
VCID: 334BC9732BA5
1 Fault Found:
005634 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0010 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 28059 576 91826
VCID: 73CB09736B25
1 Fault Found:
02781 - ASR/ESP Button (E256)
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B5BE15303F5
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003832244
Coding: 018E0F130004140000110D000000000000087F065C
Shop #: WSC 20014 576 11809
VCID: 2B7BD113F395
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 20014
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: Q4 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD06U0C8
Coding: 0020788
Shop #: WSC 73430 790 00000
VCID: 3B5BE15303F5
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76CD30677857
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 910 C
Component: KOMBIINSTRUMENT VD1 3562
Coding: 0007401
Shop #: WSC 73430 000 00000
VCID: 334BC9732BA5
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061140706
Coding: 7D3F0340072303
VCID: 2A75D417FC6F
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3562
VCID: 334BC9732BA5
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2346
Coding: 0000756
VCID: 364DF06738D7
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3449CA6F2EAB
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01D002007F2D8505485F861004CC
VCID: 79D73B5B4949
Part No: 1Z0 951 171
Component: Innenraumueberw.008
Coding: 00000000
Shop #: WSC 00000
Component: Sounder No Answer
Component: NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000756
VCID: 3753FD633FDD
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
VCID: F4C98A6FEE2B
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 B HW: 1Z0 035 161 B
Component: Radio FO3 013 0028
Revision: 00013000 Serial number: SKZ7Z3F0049315
Coding: 0040402
Shop #: WSC 28059 576 91813
VCID: 2D7FDF0BCD81
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2435
Coding: 0000144
VCID: 3245CC77D4BF
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 334BC9732BA5
End ---------------------------------------------------------------------
Check the fault code in #46, looks like your alarm horn/sounder is bad. Replace it and you should be fine. As for the constant illumination of the dash, there is no such setting that can be done here - sorry.
Cheers.
Is the sounder the same as the horn? If so, the actual horn works fine.
Alarm Horn/Sounder (H12) is different from the normal (honk) Horn (H).
thanks will have to try and find its' location and part number!
it lives under the o/s/f wheel arch at the back.
cheers - any idea on a part number and price? Presume it is a straightforward swap?
Sam
