Cheap spacers..
These are not Hub-centric so will cause stress to your wheel bearings and bolts :doh:
You can get away with up to 5mm with 'flat' spacers normally since most hub lips are 8-10mm.
Anything over 3mm will typically require longer bolts.
They are custom drilled hubcentric jobbies, basically I guess you tell them what size bore you have (57.1) then they drill the middle out for you to fit.
Cool so 3mm is ok for standard bolts, great, thanks! I guess that should be enough to clear calipers... :D
Flat spacers are the ones I've linked above? And non flat ones which will have extra lip on the centre bore I'm guessing.
Sent from my Desire HD using Tapatalk
