High level brake light
Any idea hows you remove it just emptied the shopping out of the boot and when I closed boot there were loads of dead skeletol flies, cant see how I could get to them so thought access via high level brake light. Seen theres two clips at side of light unit but there solid presume this is the way in??
any pointers :thumbup:
i think you get to it from underneath inside the boot
i had same when i noticed the dead bugs in the rear light...went thru the boot and basically bent the strong clips to free the light from the apperture...seems the clips were pressed into part of the parcel shelf hence hard to remove...i used a damp cloth to adhere to the dead insects, and althought it was fairly easy to put the light back in, i did use some strong gaffer tape to hold in position when light was reconnected, which made it easier to do next time the bugs want to see a red light :giggle:
