VRS headlights
Hi all, i picked up my vRS today and im more than happy, but looking at the car closely (like you do) i noticed a blue lamp in each headlight cluster. What is it for? i've tried all combinations of lights but it hasnt come on. please help as this is bugging me.
ALL headlights are standard fit
Yours has LED Daytime running lights which dim and act as sidelights when you switch on the lights
The bulb you are referring to is not wired up..Its in the unit as built in the factory for Cars without LED DRL's
Cheers for that.
If you snooped around enough you probably could wire it up so it comes on the the DRL's in the sidelight config. Would take a bit of jiggery pokery but it would be cool.
