Adaptor Widths
Hi Guys
i know this will be pretty useless without pictures ect and will be quite hard to gauge what size adaptor i need but o well.
Currently running 16x6.5 ET41 (i believe) steels on the fabia, 10mm front spacers and 15mm rears.
Iv got some white merc 8 pots to fit which are 5x112, so adaptors required. my question is do you think i would have any problem running 15mm fronts and 25 rears with 16x7.5 ET41 wheels? tyres fitted will be my existings ones which are 195/45's up front and 205/45's on the rear so these will just stretch onto the merc wheels nicely i think
Any opinions on how it will look, anyone who has used similar set ups and where you have purchased adaptors from
Quote from venom motorsport is £166 for 2x15mm and 2x25mm which i dont think is overly bad (FK ones)
Cheers, Elliott
I had adapters from venom fk as well I can vouch for them, good quality.
Thanks mate, can i ask what adapters and what wheels you ran them on? just trying to gauge how 15mm and 25mm will sit compared with my current set up :)
I had 25mm thick adapters on a 5x112 pcd 25 mm made my wheels stick out past the arches which I'm led to believe is illegal, these were 8.5 wide though.
