Swing Radio + Towbar
As the topic says - I have now the towbar fitter (original Westafalia by Skoda BG). As for the coding - I have my doubts everything is done correctly. Here's the checklist:
1) When I select reverse, there is no visual indication that i'm towing something (with Thule EuroWay G2 921 bike carrier fitted & connected (7-pin)) - NOK?
2) Again when on reverse, constant signal from the parking sensors that I'm about to hit something + relevant picture on Swing display. - NOK
3) The rear foglight is not operational when the bike carrier is connected - OK
4) The alarm goes off when carrier is disconnected
Any ideas if everything is OK or if not - what's wrong?
Sounds like half the coding was done. Over here the EXACT same happened when people did the coding at the dealer's. Fog OK, Alarm OK, everything else NO.
I took mine to a person with a VCDS laptop to have it fixed in the end.
Dealer could not fix it after 3 attempts. I ended up going to see Gizmo as well. Top bloke.
As I have a VCDS cable now, I'll try to fix it with remote support from Gizmo68 (many thanks!). I'm just amazed that no one else has this combination (Swing + Towbar, correctly coded).
Many thanks to Gizmo68 for the help, after some tests with VCDS I decided to push Skoda BG to finish their work. Of course the mechanics there tried to explain me how they don't have Westfalia stand for testing the towbar (maybe I had to get them the stand), how they are not sure if with 13 to 7 pin converter the Yeti can understand that there is something attached behind it, and so on, and so on. Luckily a guy that was responsible for the translations of all documentation came, confirmed that it's not working as it's supposed to be, and with VAS5052 for under 2 minutes managed to code it correctly.
This is what I see now on the Swing display, when I have the bike carrier attached, and select reverse:
And the carrier in question:
Sorry for the bad pictures, I can put better ones some other day.
So there you have a picture of the elusive combination of Swing radio + trailer attached ;)
