Bulb warning light
Hi all. My bulb warning light has now come on twice. Vehicle status says to check left rear brake light. The first time it went off before I had chance to check. This time it was still on when I got home so I checked and the brake lights were ok, but the warning light was still on. It has now cleared again.
Any ideas?
i had this on mine - the brake light is an (18watt??) bulb, but is controlled under the can-bus system for Side-Slights.
In my case, it was a dodgey connection onto the bulb; sometimes it would work, others it would not... Cap-less bulb - poor design really, but it works... sometimes!
Pull it out, and try the connections - bend (gently) the connections on the bulb out a we' bit...
Al.
Al.
Will give it a go.
Cheers.
