help with fan ref climatronic
Hi Folks
I may be setting myself up for ridicule but I could use your help please................
How do I get the fans to work without turning on AC or climatronic?
it's more comfortable to get some airflow from the dash when you are driving with the sunroof open but, for the life of me, I can't get the fans to work without the AC or climatronic kicking in.
I have tried referring to the manual but it seems to be written in Chenglish
any offers?
Edited by Bohica
That's what the ECON button is for - it provides no cooling.
no econ button!
You must have an a/c button then. Pressing that switches off the cooling.
~slaps forehead~ knew it would be something simple. Was sure I had tried that one already. Thanks
Set it to a low temperature using the rotary control. Press the auto button so that is alight. Press the a/c button once or twice until there is no light. You can also use the +/- button to up the fan speed but to get ambient air you need the temperature set reasonably low - say 18 or 19C.
As long as the air con light is off, there is no air con compressor etc working. I use these settings a lot once the car has been cooled by the air con.
There is no Econ button on the Yeti Elegance.
