Sluggish with air con
Hi all
I have an annoying problem with my 2006 Elegance 2.0 tdi DSG Octy 2.
The car is fine when I am accelerating or don't have my foot on the gas. However if I am cruising at say 50 I get a very slight jumping. The issue tends to mostly disappear once the engine temp has reached 90 OR if I have the air con off. On a very hot day it can actually stall the car at traffic lights until the engine is warm.
With the air con off it is fine - so I went and had it re-gassed. I think the problem mostly went away but is now back?
Is it likely I have a leak in my air con or is it likely to be something more serious like the compressor?
Dave
I think this sounds more like an issue with the idle stabilisation or the cold enrichment than with the air.
Well I can rule out gas as I decided to go and get it checked. All the right pressures etc.
At my last service the dealer said a code was coming up that the battery is becoming weak. Should make any difference to this should it?
