Parktronic Spacers
Do have aftermarket rear parktronic installed. The holes drilled are 22mm. Now I want to install original sensors, but original require 18mm holes. Do anybody know where to get spacers/clips for filling the gap ?
Something like this:
Nope !! rubber grommets perhaps ??
Found original Skoda parktronic sensors holder with bold plastic trim. Outside diameter is 28 ( as far as I got from description) and inside is standard for 16mm sensors + thin rubber coming as set.
Flat ones: 1Z0919491G
Cornered: 1Z5919485C
Will visit dealership today to confirm and order.
Data from here (sorry , on Russian)
Edited by Shahoff
I saw your sensors today, stand out a bit in black will look better after a change and splash of paint B) :yes:
Did you get the fronts on too, didnt want to go look in case security came out :giggle:
