Replacement Bulbs
hey all!
Looking at getting replacement bulbs for my headlights to match my xenons. I know that the LED sidelights must be the CAN BUS compatible ones, but are there any restrictions on the main beam bulbs?
These are the ones I want to get, as I've been very impressed with them in my Fiesta before I bought the vRS:
http://www.ebay.co.uk/itm/Ring-Xenon-Max-Performance-Headlight-Bulb-H1-55w-Each-/270793868635
I might also be changing the indicator bulbs (front and back) to silvatec ones, so if there's any restrictions on those I'd appreciate the info on them too!
Thanks in advance!
- Sent from my iPhone using Tapatalk
Brilliant, thank you! :)
Just bringing my topic back up, what indicator bulbs will I need? :)
I have a pair for the front headlight. Some say the are good but I personally think it does show enough light during the day. At night are good.
I think the reason for this is cause the bulb housing is to far back on the headlight and when activated the brightness does not glow enough to reach the front with glare enough.( at night ok).
They must bee canbus, if not they may work but blinks to fast as if bulb blown.
And those above ones will be fine for the front and back I guess?
Yes, there is a neat little feature on the same website linked above where you enter your car details and it lists all the bulb types for your particular model/year.
