are these clutches any good?
my clutch is going in my fabia vrs and as im looking to increase the power in the following months i thought a performance one would be a better buy,
trawling through sites i found this one on ebay,
has anyone had one fitted to there car and if so does it work or is it just a ebay special like most things?
http://www.ebay.co.uk/itm/SKODA-FABIA-VRS-SOLID-FLYWHEEL-CARBON-KEVLAR-CLUTCH-/280649606534?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4158052586
Its been covered THOUSANDS of times on briskoda, go on google and wack in techniclutch briskoda, your sure to get some hits! I belive sivxr has fitted one, touch wood his not had a problem with his
Been discussed many a time. Only been tested up to "remapped power" on here. Which is pointless since a standard clutch is fine at that power too. I'd spend the money on a sachs kit myself
Matt
avoid with a sh**y stick then really?
will be ordering a sach clutch monday morning to go with my kw's and new wheels :)
They are basically a standard clutch with painted parts.
If you want an uprated clutch then look at a sachs or helix.
