Gearbox or clutch or flywheel
hi taxi driver in north east got prb with my octy 1.9 sdi just had new clutch fitted ok for 3 days then started whining then grinding probs getting gears
then just started grinding even in neutral gearbox? or flywheel or dodgy clutch? help!!!!!!!!!!!!!!!
hello there sounds not to good go to the forum on this site about matainence etc and ask there i am sure someone will help xx
I presume the gearbox was OK before the clutch was replaced? I would suspect that the new clutch is either faulty, is the wrong one, or hasn't been fitted properly - the latter being the most likely. And whoever did the job should have mentioned if the flywheel needed replacing as well.
