removing brake bracket on Calipers
Hi all , im changing the back bearing on my 2006 oct, used a m18 spline bit to get the bolt off then removed the break calipers, but then i got stuck i need to remove the bracket that holds the calipers,so i can get the disk off, there are 2 bolts that need a spline bit is well anyone know the size for them,
Thanks.
M14 spline iirc.
Thanks ,nice one
Yep. M14 (or 14mm) triple square / splined bit. Got one off ebay cheap when I did my rear disk change two weeks ago.
