skoda fabia 04 1.2 abs pump
Hi all.
I own an 04 plate skoda fabia 1.2,on which the abs fault light has come on.
The fault code showed up on diagnostics as v39-ABS return flow pump, which i see seems to have happened to a few members of this forum!
I notice that the problem seems to have been solved for a lot of people by replacing a blown fuse.
Please could anyone tell me what fuse i should be replacing on the 1.2 model if it turns out to be blown, what ampage it is, and where it's located???
Any advice greatfully received!!!!!
many thanks!
Don't know the exact but check the metal strip fuse links in the compartment on the battery box lid.....look for fine cracks in the links. B)
Thanks-I really appreciate the swift response to my panic!!!! sure enough there is a crack in no.6 fuse,will replace and post thread as to wether this remedys the problem! all the best.
