octavia SE spec?
hi there early next year im planning to get a skoda octavia 1.6 TDI CR but im looking at the SE trim but does the se come with MAXIDOT, not really bothering me but does the normal trip comp tell you the same info. and what radio does the SE come with is it a touch screen? ;)
Hello,
It doesn't come with Maxidot. You have to get extra info from it. Otherwise, what's its purpose?
Radio, it's Bolero touchscreen.
Look here for extra info: http://www.skoda.co.uk/GBR/Documents/brochures/cars/brochure_octavia.pdf
Adrian
Hello,
Adrian
hi there no just asking if the normal trip gives you average MPG temp out side ETC.. that stuff what does the normal trip tell you? :yes:
Hello,
The onboard computer tells you: the outside temperature, driving time, current MPG, average MPG, range you can still drive with the level of petrol you have in the tank,
distance driven, average speed, current speed and also the value of the speed you set to get a warning.
You can switch in between 2 displays: a single trip display (driving info from the moment the ignition is switched on until is turned off) and
a "total trip" display (driving info for up to 20 hours or 2000 km of driving).
Adrian
The normal display tells you a bulb has blown, or a door is open. The maxi-dot tells you which lamp or door it is.
ok sounds good then just what i'm looking for thanks :thumbup::thumbup:
Now i think i got a good deal at the moment i have a octavia 2008 old shape now i pay £286 monthly and in feb coming all the finance is paid off but for a new octavia SE tdi 1.6 tdi CR and beacause ii'l trade my old octavia in for £2000 off i will be £310 a month not to bad i think :thumbup:
