Tyre Pressure For VRS 225/40R18 Y92
I need help please been on numerous sites put in my reg and asked what my tyre pressures should be with no result. I can't make head nor tail of what it says on my fuel cap. Help please required.
My tyres are 225/40R18 Y92.
Help please.
The pressures listed on the filler cap are in Bar.
If your guage is in PSI, then use this convertor: http://www.centauro-owners.com/articles/psibar.html
2.2Bar, which is a pretty common recommendation, is 32PSI.
Hope this helps.
cheers wardy.
Help please.
It is split as normally loaded (3 people + some luggage on picture) and fully loaded (5 people + lots of luggage).
Then there is a separate pressure for Front vs rear.
So decide if you are normal or loaded, find the correct tyre row then read across for Front tyres and rear tyres.
Note that they are in BAR, which most gauges should now do, if not go on the web and convert Bar to PSI.
I run mine @ 32 PSi All round. (225/40/18 Rainsports 2 )
