Cruise Control Activation
I have read on here about fitting cruise control to a 2005 vRS and I am thinking of doing the same.
However its mentioned that once installed it has to be activated via VAGCOM. Is this only available from the dealers or can someone point me in the direction of an OBDII scanner or similar that I can buy to do it myself.
Many thanks
Has to be vagcom mate! Look in the sticky in vcds and see if someone local to you has it and will do it for some beer tokens. Otherwise it's a dealer mate.
