Tailgate Plastic Panel vRS Hatch
Has anyone replaced the plastic panel inside the bootlid of an Octavia Hatch? (Mk2 vRS pre-FL, if it makes a difference)
A family member who shall remain nameless-to protect the guilty! :D - slammed the boot down on a mattress in the boot, forcing it when it wouldn't shut.
The end result is a cracked tailgate panel, with a good 15-20cm full-thickness crack so I'm not convinced a repair is possible.
Has anyone ever replaced one? Is it easy/hard to do?
When i removed mine there was a screw to remove & the panel is clipped into the tailgate,i just carefully prised a corner then worked my way round,you need to push the panel up towards the tailgate top to fully remove it,easy job really,bit of a fiddle to fit but not difficult.
Thanks. How much did a new one set you back? I'm wondering whether to get out a circular sander/epoxy resin instead.
I didnt buy a new one,i removed mine to find the cause of a rattle that had appeared after the dealer had the panel off to look at a boot opening fault. :)
No worries- I'll ask around and be less lazy when it comes to prices! :D
Thanks for the info. :)
Easy enough to pull off and replace. Just ask your local dealer for a discount on one.
Bought the top portion for a VW Golf a few weeks back was between £30 and £40. Its got to be in that kind of ball park.
