12v socket
Anyways, one thing I would like to know is there anyway to rewire the 12v socket through key because it runs even when the car is off and I lost my car battery accidentally by charging my laptop overnight.
Regards
Alam
I always thought the socket should switch off after 10 minutes of the ignition being off.
Just run a cable from the fuse box, connected to an ignition switched fuse, to the connector at the lighter. Simply snip the existing supply cable, isolate the supply end properly, and connect the new cable direct to the end already going to the socket.
This was one of the first things I did on mine, and aI used the same switched supply when I fitted the 12 volt socket in the boot.
Mike
Thanks Mike, will try this......
Hey Mike
Just got confused after opening the fuse box, is it possible for you to explain in detail or post a picture for assistance I will be greatfull to you.
Regards
Alam
Mike
Hey Mike
Regards
Alam
