front susension squeak
hi got a skoda octavia 51reg tdi the near side front suspension squeaks like mad when u go over bumps , but if it rains it goes off for a few days it driving me mad sprayed wd on all bushes on that side makes no difference , any ideas
Either a worn ball joint or anti roll bar bushes. The anti roll bar has a plastic sleeve which can sometimes cause this too. Seer if some copper slip on the roll bar bushes helps.
I thought the ARB sleeve issue was only on the vRS?
Anyway, rather than Water Dispersant 40, I'd try a few drops of brake fluid (old stuff is fine for this) on the wishbone bushes, since the problem may just be a dry bush.
You might well be right Ken, I don't know to be honest. :S
