rear fogs
hi all
is there any way to get both rear fogs working?
was checking my bulbs and noticed that there is 2 dual filiment bulbs for the tail and fog lights
but only the right side works.
i have checked the bulbs and they both work correctly but it seems the lh side is not connected?
is there anyway to get it working?
tar
phil
Run a wire from the live feed on the working foglamp
to the same connection on the opposite cluster.
You can hide it behind the trim panel that runs along
the base of the tailgate, inside the car.
It's already earthed so that should do you :thumbup:
Have a search, a few have done it on here, there's bound to
be a write up somewhere.
i just read a couple and it taked about VAGCOM can be used
just wanted it check
VCDS isnt required! As Garry said it's a matter of running a wire across from the O/S to the N/S!
If you know anyone who can make up ISO connectors, Ask if you can blag a female pin!
