Codes 16486 & 01314 - serious?
Hi All,
I've been getting the ASR dashboard warning light coming on intermittently on my mk1 Octy vRS.
Plugging in a Ross-Tech VAG cable gives me the following info but I'm not sure where to go from here or how serious these codes are. I'd appreciate any advice. Thanks.
Address 01: Engine
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT G 0002
Coding: 11500
Shop #: WSC 31480
TMBER41U748737224 SKZ7Z0C2163964
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
UPDATE:
I note the Ross-Tech site states 16486 could lead to a loss of power!
They state the following about code 01314:
Engine Control Module stored a Code which influences other Control Modules Functionality.
To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
Edited by Mateus109
16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
Possible Symptoms
  • Probably no serious malfunctions
  • Loss of power
Possible Causes
  • Wiring and/or connections (short circuit?)
  • Mass Air Flow (MAF) (G70) defective
Possible Solutions
  • Check wiring and connections
  • Check / Replace Mass Air Flow (MAF) (G70)
Special Notes
  • In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
  • 01314 - Engine Control Module: Check DTC Memory
  • Possible Causes
  • Fault(s) stored in Engine Control Module
Possible Solutions
  • Check Engine Control Module for Fault Codes
Special Notes
  • Engine Control Module stored a Code which influences other Control Modules Functionality.
  • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
