Coding issues after new CAN & Columbus
I've treated my '07 Octavia to a Columbus unit and a new CAN Gateway today (7N0 907 530 C from 1K0 907 530 K), cleared all fault codes and run a new scan. The results are below my questions.
First off, why does the new CAN only have Bytes 0-2 active? Anything from 3 onwards is blank? Have I missed a trick?
Should I have 37 - Navigation and 56 - Radio ticked in the CAN Gateway instalation list? I read somewhere that you needed to have one or the other,but not both! I have 56 - Radio unticked, but it still shows up on the 'Select Control Module' window.
I understand the 008212 - Antenna 2 problem (I don't have two radio antennas as yet), but 00856 - Radio Antenna (according the Ross Tech Wiki) suggests a 'short to ground'!
Would this fit with my hearing a 'clicking' noise from the speakers (sounds like a static click) when VCDS queries 37 – Navigation or 56 – Radio?
I've also noticed that lights on stock CD changer are always on (don’t know if that has changed, but can’t remember seeing that before).
I read on My-GTI.com about changing the wiring on pins 2 & 3 when changing from second generation to third generation head units. When I checked, I did not have anything on pin 2 only a wire on pin 3!
00862 is not on the Wiki so I have no idea why this is being flagged up.
Everything seems to work OK, but if there is an electrical problem I'd obviously like that to be solved along with the issues surronding the new CAN having very little for the long coding helper to go off.
Any suggestions or answer will be greatfully recieved.
____________________________________________________________________
Saturday,08,October,2011,18:00:02:13904
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMB***1Z********* Mileage: 165790km/103017miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Not registered 0011
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LD HW: 03G 906 021 LD
Component: R4 2,0L EDC 000SG 8514
Revision: --H06--- Serial number: SKZ7Z0G4110335
Coding: 0000072
Shop #: WSC 73430 790 00000
VCID: 6CDD3D443610
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F87BA0817E6
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1Z0 820 047 D
Component: Climatic PQ35 010 0301
Shop #: WSC 00000 000 00000
VCID: 346DE5242EA0
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004766802
Coding: 81880F211004140000110D000000000000087F075C0000
VCID: 6CDD3D443610
Part No: 1Z2 955 119 C
Component: Wischer 090207 022 0601
Coding: 00055223
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD11NW3N
Coding: 0020788
VCID: 3D7BC0001DEA
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000012
VCID: 74ED25246E20
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4110335
Coding: 0003401
Shop #: WSC 27012 576 175240
VCID: 3669DF2C38DC
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 191210F2000277
Coding: 352303
VCID: 3065E934DAB8
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 75
Mileage: 165781 km
Time Indication: 0
Date: 2000.00.00
Time: 13:33:12
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
VCID: 3669DF2C38DC
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680 A
Component: RNS-MID H41 3804
Revision: AB001001 Serial number: SKZ6Z7Z5703265
Coding: 02000400040000200000
ASAM Dataset: ------------------------- ------
VCID: 2F67EA48C786
4 Faults Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 10
Reset counter: 1
Mileage: 165776 km
Time Indication: 0
Date: 2000.00.00
Time: 13:54:31
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 1
Mileage: 165776 km
Time Indication: 0
Date: 2000.00.00
Time: 13:54:34
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 165776 km
Time Indication: 0
Date: 2000.00.00
Time: 15:56:47
00862 - Antenna for GPS Navigation (R50/R52)
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 41
Mileage: 165781 km
Time Indication: 0
Date: 2000.00.00
Time: 14:35:04
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
VCID: 3875D11432C8
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 73430 000 90108
VCID: 356BD82025DA
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F04850540085F96907CA0
VCID: 830FF6F8BB8E
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
02483 - Module for Locking of Rear Lid (F327)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 3973D41009C2
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2F67EA48C786
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 10
Reset counter: 1
Mileage: 165776 km
Time Indication: 0
Date: 2000.00.00
Time: 13:54:31
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 1
Mileage: 165776 km
Time Indication: 0
Date: 2000.00.00
Time: 13:54:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 165776 km
Time Indication: 0
Date: 2000.00.00
Time: 15:56:47
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 41
Mileage: 165781 km
Time Indication: 0
Date: 2000.00.00
Time: 14:35:04
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3777D2283FD6
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
VCID: 3875D11432C8
End ---------------------------------------------------------------------
Hi
You need to have both 37 navigation and Radio 56 ticked
that will sort out the gateway incorrectly coded
The Columbus faults have nothing to do with the gateway swop
The antenna requirements are different on the sat nav to the standard radio
Check the coding on the columbus
is your GPS signal good?
Ed
GPS Signal was pretty good today.
I took a drive with the Columbus showing how many satellites were detected and how many were being used (not the right terminology) and generally it was showing 10 or 12 as being available and between 6 and 10 actually being used, so to speak.
I'll tick 56 as well, clear fault codes and see what happens. I think it was on a VW forum that I read about ticking one or the other, but not both.
Should there be more Bytes 0, 1 & 2 available on the new CAN? It seems a backwards step in that respect as there were 0-7 on the old one. When I select 19 - CAN Gateway, it flags up a warning message in red on Byte 0:
"Only Limited Coding Information is available on this Control Module.
If you happen to need additional Details please contact Support at Ross-Tech.com
Coding is normally done using the Factory and Software-Version-Management (SVM)."
What does this mean?
It might seam backward, On older ones you had 2 options on how to code a gateway, either use the installation list or long coding.
with so many different options on newer cars the bytes would have increased. don't worry about the message, the only things of importance in the long coding are RHD, vehicle type and number of doors.
The faults on the columbus are not that major, providing everything is working
DTC 00856 and DTC 00862 are intermittent, most likely already taken care of and remainders from the installation/retrofit.
DTC 00821 Check the Special Notes about the 2nd Atenna!
DTC 01042 Check the Special Notes about using a proper WSC!
The Gateway Coding itself is correct, the Installation List is not. In fact the Auto-Scan shows just that. ;)
Did you check out our RNS510 Retrofitting Page? :)
Ross-Tech WIKI: Navigation System (RNS510) Retrofitting
Edited by Theresias
Eddie, you are a mine of info.
Just been and had another look and ticked 56 - radio as well... AND, I remembered to clear the DTC's this time (Doh! and apologies for stupidity).
The only ones that have come back are the two that relate to the aerial.
However, the Auto Scan diplay (the one that is active whist scanning) says that the CAN Gateway has no faults, but when the file is saved and then open it shows one fault! (Wish I could put screen dumps into threads so you could see what I mean).
Why the discrepancey?
And why the static clicks via the speakers when scanning the stereo?
Coding: 352303
VCID: 3065E934DAB8
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 75
Mileage: 165781 km
Time Indication: 0
Date: 2000.00.00
Time: 13:33:12
Just looked up DTC 01044 of Ross Tech Wiki and a thought came to mind.
When I was ticking boxes in the Installation List on the CAN Gateway, there was no contoller 00-Steering angle sensor, but the sensor had moved to 04-Steering angle sensor (so I ticked that one).
Was that a mistake on my part as well?
Edited by KBPhoto
No, older modules had the sensor listed as 00, newer ones as 04. No problem there, your change was good. If you remain having troubles after the above suggestions please post a fresh Auto-Scan.
just double check the whole of the installation list, when I have done some I have forgot one item or ticked one by mistake
Theresias: Thank you for pointing me back at the relevant articles - I had read them, but had ignored the parts about WCS's. Cleared all fault codes first thing, entered a WSC on 37 - Navigation and everything seems to be fine.
Still have the 00821 fault code on 37 - Navigation and on 56 - Radio which is to be expected considering I only have one aerial.
Eddie-NL: Double checked the list and all was correct. Will either get one of the adapters you pointed me to or fit a second aerial under the front dash using a switched live from the fusebox.
Still not sure about the discrepancy between the scan display and the one that shows when you got o save / print it...
It seems as though VCDS was opening a 'older' version of the log file to show me until I saved them with a different name. Then it brought up one that matched the scan data.
All seems well and good - No battery drain - Understandable fault codes - Columbus working fine.
All I need now is for the seller to send me some maps of Western Europe rather than Eastern Europe and I'll be off...
