urgent help with stream
Hi
Can some one give me some advice.
I went to turn my octavia off this afternoon and none of the buttons work on the stream headunit and it will not switch off, even with the ignition off.
Any help as to what the problem is will be gratefuuly recieved.
thanks
Pull the radio fuse in the fuse box under the bonnet behind the air filter.
Put the fuse back in after a few minutes and see if it has started behaving itself again.
If it hasn't you will have to get a scan done for fault codes before going any further.
