Hi
Hi everyone, just joined.
I am currently on my second Octavia VRS. Had a mark IV Golf GTI before and the Octavia is a 100 times better!
I am currently looking into fitting a dump valve, If anyone has had one fitted I would be interested to know your thoughts.
Cheers :thumbup:
Hello and Welcome:D
easy to fit,take 15mins.
1)remove the engine cover(4 quick release fasteners)
2)force the clamp that holds the bottom loose so you can pull the excisting DV up
3)remove the upper hose from the DV
4)place new jubilee clip around mounting point and push new DV into position
5)tighten jubilee clip up and push top hose onto new DV
6)start engine to make sure no leaks
7)replace engine cover in the knowledge you'll not be loosing any boost pressure
hope this helps Burn,
Welcome on board :thumbup:
