engine noise
hello all im hoping i can get sum help iv got a 2001 octivia 1.9 tdi and it has ratting noise from engine wen i rev it go's i think its cuming from Alternator Belt Tensioner damper well i think that what it called but wen i push on it with my finger it stops if it is the Alternator Belt Tensioner damper cud i do it my self and if so what kit will i need or will i have to take it in to be dun this is the only thing thats rong with this car its got 326000k on it and still going strong i love it hope i can get sum help thanks all for reading
It could either be the tensioner for the aux belt, or possibly it might be brought on the free wheel pulley starting to fail on the alternator.
To change the tensioner you need a spanner to fit onto it, and a locking pin (can use the one from a the replacement one) and a new belt. I think to fit the tensioner, you need to remove the pulley from the PAS pump (held in with a couple of allen bolts.
An extra pair of hands is handy for when taking the tension off the belt to fit the locking pin, and also for taking the tension when removing the pin (upon fitting)
Edited by mbames
thank you iv been out today and had a good look again and it is the alternator pulley so been looking and fond a Alternator Belt Tensioner damper with the pulley for £57 so would it be better to replace the hole thing or just the pulley just don't wont to be doing it again in a couple of weeks thanks and sorry for all the questions
Given the mileage of your car, I would change both assuming they are original. The pulley on the alternator can be a bit of a pain, due to the faffing about in getting the alternator out (PAS pump, rad fan, etc). You need a fancy tool for changing the pulley on the alternator, unless you can get your friendly garage to do it for a few quid.
Is that £57 for both parts? That sounds very cheap....
ok thanks and yes they are the original ones so will do both and will get my friendly garage man to do it i think but thanks for your help will post when it dun and thanks again
sorry and no just for the damper my mistake sorry will pind a price now for the pulleys thanks
The pulley is about £32 but you should be able to get a 25% discount from ECP with the discount code on here. The part number should be 022903119C.
thank you for that will find them now got the damper that on its way but thanks again mate
