Fault code on Felicia Diesel
Hi all, Just pluged in the computer and found the following codes:
Address 41: Diesel Pump Labels: 028-906-125.LBL
Controller: 028 906 125 B
Component: Saugdiesel FIA V01
VCID: 1359743A727B
6 Faults Found:
01266 - Glow Plug Relay (J52)
31-10 - Open or Short to Ground - Intermittent
01269 - Commencement of Injection Valve (N108)
30-10 - Open or Short to Plus - Intermittent
01052 - Load Signal Potentiometer (G157)
28-10 - Short to Plus - Intermittent
01204 - Engine Temperature Sensor (G27)
01169 - Door Contact Switch Driver Side (F2)
29-00 - Short to Ground
01209 - Engine Speed Signal - Alternator Terminal W
03-00 - No Signal
car seems to run fine except that the Temp sensor needs replacing as the temp satys at 70 degrees when driving and the thermostat is working. I am puzzled by the alternator fauld and door contact as these are shown under Address 41: Diesel Pump.
Can anyone can shed any light on these faults?
Many thanks
Skoda Survivor
