problem VAG COM
hi
i have a problem with vag-com and my octavia 2.0 TDI 140cv year 2005
I Used vcds version 10.6 and 11.2
When i press autoscan after 4 second error "function not supported by the gateway"
When i press Select control module and choose any options after 4 second "no response from controller"
WHY???
PS in the options menu when i do the Test, result OK!!!!
sorry my english
Its not a cheap cable from Hong Kong is it?
Is the ignition on? :)
I had this yesterday, use the test and save all comes up fine.
I sorted it on mine by using reset button in vag-com to factory
Also make sure the Interface is plugged in properly
That's your problem - a cheap and nasty Chinese knock off cable.
VCDS works perfectly with windows7 :thumbup:
Buy cheap buy twice
ok, i now feel the vag with other cars "Audi VW" and i know
Edited by devilx
I test my cable with audi a4 and golf works perfect, why not in my skoda octavia?
MK4 Golf by any chance? they are non CANBUS whereas your Octavia needs a CANBUS interface (genuine Ross-Tech)
As above. Cut-off is about middle of 2004. All cars before 2004 can be used on old Vag-com. Newer cars 2005+ need proper VCDS. Just buy the full program! :p :p :p
