Felicia lights and wipers failed
Side lights work but dip beam not working nor are wipers. Main beam works in the temporary (flash) position but not if you use the permanent setting. Initially stopped and a quick bash of the fuse box made them start again, but after 10 minutes stopped again. At one point the speedo light went out then cam back on again. Anyone had a similar problem? (and found an answer?).
Starter terminal did it on mine.
this /\
check the yellow wire to the starter motor is attached ok, if it is then it prob needs the main power relay changing.
Thank you very much for the fast replies, I will check these.
