Steering control module swap
While planning to do the the project of retrofitting MFSW, I'm preparing to swap my midline steering wheel module to a highline one.
I had checked the link http://wiki.ross-tec...Module_Versions to know which module should I buy, but you will see that there is a lot of models which are highline, so what should be taken into consideration: is it only Slip ring Type and Steering angle sensor? or should I replace with the same software version?
I have 1K0-953-549-BF which is midline for Slip ring type 2, a steering angle sensor installed at slip ring and software version 0101,
Do you think it will work if i use 1K0-953-549-AG which is highline for the same type of slip ring, also with a steering angle sensor installed at slip ring, But software version is 0070
