Fabia 1.4 OHV MPi 134000 miles- Miss-fire when driving
Hi all,
Re:Fabia 1.4 OHV MPi 134000 miles- Miss-fire when driving.
Started off as a miss-fire at low revs, car would stall unless more revs given.
Now varies from that to holding back at what ever revs.
Also, timing chain very noisey and engine is leaking oil although not needing topping up.
I've already changed spark plug and Ignition coil pack with no effect.
Has anyone had / fixed a similar problem?
Thanks.
My next move would be a compression or leak down test.
I've had a crank sensor do exactly the same thing on mine, dead easy to change ontop of the gearbox.
Cheers guys, I will try them
